Tak sobie myślę...skoro było krzywo i zostało skalibrowane na prosto, to czemu nie wychodzi mi ponowna kalibracja. Czy zapis do epromu przebiega w tle, bo nie widać żadnej reakcji po naciśnięciu EXIT. Ta kalibracja to jakaś jedna wielka ściema. Dla sprawdzenia poustawiałem drążki byle jak i też niczego to nie zmieniło. Nie ma ktoś relacji na żywo jak to prawidłowo wykonać?
Znalazłem jeszcze taką instrukcję, z niewielkimi różnicami, zrobiłem krok po kroku i też d... Push the right lower trim tab to the left (aileron on a mode 2 TX), and the left side trim tab up (Throttle trim on a mode 2 tx), and while holding them, turn the Tx on. You will get a screen that shows the version number of the firmware, with four zeroes (0000) at the top of the screen. Center both sticks in their range in all axis, and press the menu button until it beeps and release. The screen number will change to 0001 Move the right stick to the upper right corner, and press menu, and you should get a beep, and the number on the screen will change to 0002. Put the right stick in the lower left corner, and press menu, and get a beep, and the number will change to 0003. Release the right stick, and put the left stick in the upper right corner, and press menu, get the beep, and the number will change to 0004. Put the left stick in the lower left corner, and press menu again, get the beep and the number will change to 0005. Center both sticks, and press menu, get the beep. You are done calibrating the sticks.
While at the same screen, press the + key, the screen will change, and you will get the position of the controls in hex code. You can see the numbers change as you move the sticks or knobs. Press - to go back to the firmware version screen. Exit the firmware screen, and go to the Display menu item. As long as you haven't turned the TX off, you will see the hex codes for stick positions for the 4 primary controls. Once you turn the tx off and back on, and go back to the Display menu item, the numbers will disappear.
Nie wiem o co chodzi w części zaznaczonej na zielono. Nie mogę w to wejść.
Edit: Wersja mechaniczna odpada - nie ma takiej możliwości. Na razie ustawiłem wychylenia serwa na 100 i 120% i chyba będzie w porządku.
_________________ moja strona firmowa: https://gprofi.pl
