Teraz jest poniedziałek, 26 października 2026, 05:35
 Tytuł: Ciekawostka na temat ładowania LiPo
PostNapisane: sobota, 15 sierpnia 2015, 21:27
Nie moje, znalezione na "sąsiednim forum":
pawczu napisał(a):
Niedawno znalazłem w sieci informacje, że ładowanie LiPo do 4.15 zamiast do 4.20, w sposób drastyczny zwiększa ilość cykli jakie może przepracować pakiet.
Źródło:
http://www.rchelicopterfun.com/rc-lipo-batteries.html
"Maximum Charge Voltage and Current
A 3.7 volt RC LiPo battery cell is 100% charged when it reaches 4.2 volts. Charging it past that will shorten life substantially. In fact, the cell phone industry did a study looking at the effect of LiPo fully charged voltages in relation to cycle life. These tests were done under ideal laboratory conditions and of course the 80% depth of discharge rule was obeyed! Here are the results:
Charge to 4.1V gave over 2000 cycles.
Charge to 4.2V gave about 500 cycles.
Charge to 4.3V gave under 100 cycles.
Charge to 4.4V gave less than 5 cycles.
Folks in the RC world have reported similar results and one ongoing test seems to indicate if you set your maximum charge voltage to 4.15 volts per cell (if your computerized charge gives you that option), you should be able to get about 800 cycles (again if all the other LiPo usage rules are religiously obeyed). More and more people are considering this 4.15 termination voltage the "sweet spot" for both performance and cycle life for RC usage. Most RC chargers don't give you that ability, but if yours does, you may want to consider it."
Czy ktoś coś na ten temat słyszał?
Dalej w tym tekście jest mowa też o innej ciekawostce. Ponoć idzie jakieś nowe w pakietach... "high voltage" LiPo gdzie cele ładuje się do 4.35 i mają mieć 500 cykli. 20% lepszy stosunek gęstości prądowej do masy.
Thunder Power: https://www.youtube.com/watch?v=uEIQdYDbc1A
140,365,457 Wyświetlone Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
